Having acquired a Sherwood amplifier some time back i was curious about the Bluetooth interface on the front that requires a propriety Sherwood Bluetooth dongle to utilise.
Unfortunately this item in "Discontinued" and any old stock i had been able to find is ridiculously expensive, ( about the price i paid second hand for that amp).
After discovering the tech details of the interface i was able to acquire a few bits and knock one up myself and reasonably affordably.
Details
Literature,
Sherwood Bluetooth schematic interface.
See attached schematic for connections.
Anyone want to volunteer to make up a 3d printed case for the home brew dongle???
buzz out all adjacent pins and then do a continuity test on all pins.
3
Step 3
Interface to the board removed from a generic BT audio receiver.
NOTE that the numbering on the .5mm side of the breakout board is inverted, ie 1=24 ...24=1 as connector is actually mounted upside down.
Bridge pins 1,2,3 (22,23,24 as labelled on breakout board.), on breakout board and connect to audio ground on receiver board.
Bridge pins 4,5 (20,21 as labelled on breakout board.)and then connect to USB 5v on receiver board . Also bridge between pins 14 and 15 (11 to 10 on breakout board) to the 5v pins in previous step for "bt_det" pull up.
Connect pins 6 and 7 (18,19 as labelled on breakout board.)to respective audio channels.
Connect pin 12 (13 on breakout board) to USB 0v on receiver board.
Costs about $15AUD ($10USD) to build the first One as the connectors and breakout boards come in lots on 10 and 6. Subsequent dongles therefore cost about $3.50 as thats what the usb BT dongle component costs.
basically the project works a charm electrically, just need a nice housing to finish it off, i have built 2 , one for myself and another for a friend that has a sherwood amp.
are you willing to sell one of these?
