Here's an introduction I wrote to the ARITH-MATIC project: http://arith-matic.com/notebook/the-maker-spirit
![](https://cdn.hackaday.io/images/1724471518896629185.jpg)
A project log for S1-AU Mk1: a 4-bit arithmetic unit
The S1-AU Mk1 is a 4-bit arithmetic unit, designed to help you explore the guts of computing.
ah! ok - thanks for the tip! ;)
it is always good to include a picture with your project logs so that it shows up in the updates stream...
