Any need to commute or dim a 230VAC device? with this device you will be able to act on a solid state relay with a grove interface (4 wires). The goal is not to dim light source but use with motor to adjust the rotation speed.
The schematic and layout are ready to be sent for the first prototype batch. A dedicated enclosure will be design in the future.
