1Power supply
SMPS_1: Isolation transformer
- just for Isolation - designed ideally to 60kV - in real life it will be much less
- potted in epoxy 22kV/mm = 3mm gaps between PRI/SEC and core = very high leakage inductance = soft source
- half bridge topology was chosen due to high leakage inductance.
- idealy no feedback at all = problem due to leakage inductance - soft source
- to minimize leakage inductance, primary winding will be splitted in hlaf. PRIM | SEC | PRIM
- 20-50kHz
SMPS_2: classic buck converter
SMPS_3: step up
SMPS_4: current or voltage fed voltage converter - depends on power (e-beam weldes vs SEM)
- Mains -> DC, buck, full bridge
- FPGA driver
This is amazing. Might I ask where you source some of the more esoteric parts?
