Hackaday.io Hackaday.io
Sign up Log in
A basic IoT device
A basic small-as-possible IoT device, watching the house.
kjohKJoh
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
1.2k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
325
2
1.2k
2
Team (1)
  • kjohKJoh
Join this project's team
ongoing project
This project was created on 04/26/2015 and last updated 6 years ago.
Description
In addition to my interest in autonomous systems, I'm totally into seeing data about the world around me. I had some initial forays into IoT with Thingspeak, and wanted to continue that.
E.g. What's going on with the temp and relative humidity in the house. How often / how ling does the furnace / AC run?
I started with a basic AM 2302 humidity sensor, first plugged into an arduino, then a atmel 168p. I want this to be as bare bones as possible. Connectivity will be via ESP8266 whenever they arrive in the mail.
Project Logs
Collapse
  • Clean up, and on to part 2
    KJoh • 05/09/2015 at 11:57 • 0 comments
    cleaned up the board, still talking to it with the arduino.
    If anyone wants to check it out, go to
    https://thingspeak.com/channels/37003
    Pretty standard stuff, probably been done a million times, but, still.....yay?
  • A start
    KJoh • 05/07/2015 at 19:46 • 0 comments
    always good to start with a simple arduino sketch, though I intend to program this as a standalone avr based device.
    Thanks to
    https://github.com/hwiguna/g33k/blob/master/ArduinoProjects/RF/ESP8266/esp8266_ThingSpeak/esp8266_ThingSpeak.ino
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
KJoh wrote 05/03/2015 at 12:27 • point
Just because.  First off, I wanted to try to integrate the esp8266 with the avr as an exercise, but also want to do more than just temp and humidity.  Plus, I don't have one yet ... Still waiting for my 8266s to arrive.  Thanks for looking
vlatkokaplan wrote 05/03/2015 at 12:21 • point
Why are you going to use atmel168p? I have mine DHT22 connected to esp8266.
This arduino based device measures, records and uploads T, RH, BP data to ThingSpeak
Project Owner Contributor
Arduino-IoT enabled dual BME280 HygroThermoGraph
jlmyrajlmyra
A simple DIY Arduino-based device to measure the input-to-action latency in 3D games.
Arduino Latency Meter
eugene-fainstainEugene Fainstain
This is actually a modern replica of the so-called "E-Meter", device used in Scientology practices which costs several thousand dollars.
DIY Sensitive Theremino-Arduino Polygraph, E-Meter
mircemkmircemk
An Arduino-based device connected to the interwebs by GPRS to monitor and log events online using Carriots and Google Sheets
Internet-connected monitoring with Arduino & GPRS
adriajunyent-ferreadria.junyent-ferre
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "A basic IoT device", please tell us the reason.
Send message
Remove Member
