3D printed basement window holder
3D printed Basement window holder for repairs you can print
0 followers
Hi, a while ago someone ask me to print new lock mechanic for his basement windows because they where broken.
in this picture you can see the new an the old one.
there is also an example on how it should look like, unfortunately i don't have a picture of the real window
i upload the stl file for it so you can print one if you need.
the hand puller is needed to be bend with a heat gun.
windowholder.stl
simplify3d_stl - 182.11 kB - 02/15/2018 at 13:09
Download
