Tablet mount fix - 3D Printing to the rescue!
My tablet mount broke, so I decided to fix it rather than sending it to landfill.
The mount between this tablet holder and the flexible arm broke on me one day, so rather than adding to landfill and buying another one, I designed a replacement part.
I initially started with Onshape, but ran into a few issues getting things as I wanted them, so I exported the project as a STEP file and imported into Fusion 360 to complete the design.
This is actually the V2, as I initially designed the replacement part exactly as the old one, but I found the 3d printed parts couldn't hold up to the stresses that the mounting mechanism puts the part under, so I redesigned it as a socket and ball clamp design, which seems to be working well enough.
It's a three part design with a recessed socket in the base of the mount where the ball end of the arm can rest, then a part which goes behind the ball, and is then clamped down by the cap when screwed down.
Tablet Mount Adapter.zip
Zip Archive - 975.62 kB - 02/15/2018 at 19:01
Download
