nodeMCU Lua code
07/28/2015 at 19:04 • 0 commentssrv=net.createServer(net.TCP) pin=6 led_1=8 led_2=5 led_3=4 status=true gpio.mode(pin,gpio.OUTPUT) gpio.mode(led_1,gpio.OUTPUT) gpio.mode(led_2,gpio.OUTPUT) gpio.mode(led_3,gpio.OUTPUT) gpio.write(pin,1) gpio.write(led_1,0) gpio.write(led_2,0) gpio.write(led_3,1) srv:listen(80,function(conn) conn:on("receive", function(client,request) local buf = ""; local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP"); if(method == nil)then _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP"); end local _GET = {} if (vars ~= nil)then for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do _GET[k] = v end end buf = buf.."<h1> ESP8266 IoT Power Strip Web Server</h1>"; buf = buf.."<p>Lampada <a href=\"?pin=ON1\"><button>ON</button></a> <a href=\"?pin=OFF1\"><button>OFF</button></a></p>"; buf = buf.."<br><br>"; buf = buf.."<h2>Developed by Pedro Minatel</h2>"; local _on,_off = "","" if(_GET.pin == "ON1")then gpio.write(pin,1) gpio.write(led_1,0) gpio.write(led_2,1) gpio.write(led_3,0) status = true elseif(_GET.pin == "OFF1")then gpio.write(pin,0) gpio.write(led_1,1) gpio.write(led_2,0) gpio.write(led_3,0) status = false elseif(_GET.pin == "TG1")then if(status == true)then gpio.write(pin,0) status = false else gpio.write(pin,1) status = true end end client:send(buf); client:close(); collectgarbage(); end) end)
TRIAC Module
05/04/2015 at 21:52 • 1 commentThis is the TRIAC module with RC snubber for inductive load.
Should I keep the filter?
Testing the module
04/28/2015 at 23:01 • 0 commentsRight now I'm testing the nodeMCU TCP client script! The idea is to develop a basic Android app to control the power strip.
