Why I work on projects like these.
09/04/2015 at 02:49 • 0 commentsThis is my vlog, but this one is focused on my NIRGM project, skip ahead if you're not into the whole "vlog" thing.
Thanks Adafruit!
05/07/2015 at 01:29 • 0 commentsAdafruit featured my project today. I have received lots of emails pertaining to helping out with the project, Its really awesome! I need to clean up the project a bit and post it to GitHub so there is more access for everyone. I will admit I'm not the best when it comes to doing that, so I will try my best to get it all set up(Time is a huge factor). There are lot of people eager to help program, or gather data, so I need to get the design sorted out before I tell people to start building these!
If I have not emailed you back yet, don't worry, I'm making my way through them and will get to you eventually. They are all appreciated!
Thanks everyone!
Dull LEDs aren't cutting it.
04/30/2015 at 04:55 • 0 commentsRealized that I should have(a long time ago) ordered some high quality LEDs. The standard inexpensive ones I always get are not cutting it. Did a brief search on Digikey and found some serious ones for the job that should be a lot better and also are still 0603 so no need to order a new board.
Red:
http://www.digikey.ca/product-detail/en/APTD1608SEC%2FJ3/754-1542-1-ND/2514675
Green:
http://www.digikey.ca/product-detail/en/XZM2DG53W-8/1497-1162-1-ND/4745508
The IR and the NIR are already powerful enough I hope.
