Usage Commands Found!
05/01/2015 at 21:24 • 1 commentAfter digging through the data and extracting what I can from the firmware update file I found the following usage data.. It still needs to be cleaned up, but it does help to identify data on the device.
Usage commands found in no particular order.. (needs to be cleaned up
usage: fat mkfs drive# fat cat [file] file : display file fat mkfs [drive] drive : drive no.(0 or 1) 0: User, 1: System(Hidden) fat mkdir [dir] dir : create directory name fat write [file] [size] file : write check file size : write size(1-65535) fat read [file] file : read check file fat mv [org] [new] org : original file new : new file fat rm [remove] remove : remove file fat cp [org] [new] org : source file new : destination file fat lsr <dir> dir : directory fat ls <dir> dir : directory usage: test read <file name> usage: test write <file name> <file size> usage: test cp <existing file name> <new file name> usage: test rm <file name> usage: test mv <source file name> <target file name> usage: test mkdir <directory name> srom conf -f [flow] -d [val] -s [samp] flow : 0/1 (Invalid / Valid) val : 1-10,16/32/64/128/255 samp : 0-63 srom read [addr] -l <length> addr (hex) : 0xXXXXXXXX length (dec) : default 4, Max 512 (round 4byte) srom write [addr] [data] -l <length> addr (hex) : 0xXXXXXXXX data (hex) : 0xYYYYYYYY length (dec) : default 4, Max 512 (round 4byte) Usage: ping [-t] [-a] [-n count] [-l size] [-f] [-i TTL] [-v TOS] [-r count] [-s count] [[-j host-list] | [-k host-list]] [-w timeout] target_name Options: -t Ping the specified host until stopped. To see statistics and continue - type Control-Break; To stop - type Control-C. -a Resolve addresses to hostnames. -n count Number of echo requests to send. -l size Send buffer size. -f Set Don't Fragment flag in packet. -i TTL Time To Live. -v TOS Type Of Service.(AC_BE=0x00,AC_BK=0x20,AC_VI=0xA0,AC_VO=0xE0) -r count Record route for count hops. -s count Timestamp for count hops. -j host-list Loose source route along host-list. -k host-list Strict source route along host-list. -w timeout Timeout in milliseconds to wait for each reply. setup dump -m [mode] -f <fil> mode : 0-3 0 : No Dump 1 : MAC Header Only 2 : MAC Header and Frame Header 3 : All fil : 0-2 0 : Show only My address 1 : All 2 : Broadcast Frame hidden dump setup reg -r <addr> -v <data> NoOption : display register setting addr (hex) : 0xXXXXXXXX data (hex) : 0xYYYYYYYY setup ch -f <freq> -c <channel> Argumet freq or ch freq : 2412/2417/2422/2427/2432/2437/2442/2447/2452/2457/2462/2467/2472/2484/ 5180/5200/5220/5240/5260/5280/5300/5320/5500/5520/5540/5560/5580/5600/ 5620/5640/5660/5680/5700/5475/5765/5785/5805/5825 channel : 1`14,36/40/44/48/52/56/60/64,100/104/108/112/116/120/124/128/132/136/ 140/149/153/157/161/165 setup frame -l <macl> -u <macu> -b <body> -s <size> -t <tid> -r <rate> -p <power> -a <ack> -m <mcs> NoOption : display frame setting MAC ADDRESS XX:XX:YY:YY:YY:YY macl (hex) : 0xXXXX macu (hex) : 0xYYYYYYYY body : 0xZZ MAC Frame Data size : 0-1500 tid : 0-65535 rate : 1/2/5/6/9/11/12/18/24/36/48/54(Mbps) power : 0-255 ack : 0/1 (Normal/No ack) mcs : 0-7 send pn -r <rate> -m <mcs> -p <preamble> -g <gi> rate : 1/2/5/6/9/11/12/18/24/36/48/54(Mbps) mcs : 0-7 preamble : 0/1 (Long Preamble / Short Preamble) gi : 0/1 (Normal GI / Short GI) send frame -n <count> -i <interval> -s <sifs> -r <rifs> -e <enc> count : 0-65535 interval : 0-65535 (msec) sifs : 0/1 (SIFS Burst Invalid / SIFS Burst Valid) rifs : 0/1 (RIFS Burst Invalid / RIFS Burst Valid) enc : 0 : None 1 : WEP 2 : AES 3 : TKIP send help send frame -n <count> -i <interval> -s <sifs> -r <rifs> -e <enc> send pn -r <rate> -m <mcs> -p <preamble> -g <gi> sd buffer [-d | -s] -s : Single buffer -d : Dubble buffer sd clk ??? ??? : SD_CLK_CTRL sd update [filename] filename : file name sd fread [filename] filename : file name sd gcmd [number] <arg> number : XX (dec) arg : Command dependent sd dcmd [number] <arg> <size> number : XX (dec) arg : Command dependent size : XX (hex) sd clear [sector] [count] sector : clear sector count : sector count sd acmd [number] <arg> number : XX (dec) arg : Command dependent sd cmd [number] <arg> number : XX (dec) arg : Command dependent sd write [sector] <count> sector : write sector (over 0x100) count : sector count (If no <count> continue writing until you issue CMD12) sd read [sector] <count> sector : read sector count : sector count (If no <count> continue reading until you issue CMD12) wlan rate <rate> NoOption : display rate setting rate : 0 auto 1/2/5/6/9/11/12/18/24/36/48/54 (Mbps:11bg) 0-7 (MCS:11n) wlan obss <0/1> wlan ap [ssid] [channel] [mode] ssid : 32 strings(max) channel : 1-14 mode : 11a/11b/11g/11bg/11n wlan ibss [bssid] [channel] [mode] bssid : 32 strings(max) channel : 0-14 (0:Auto) mode : 11a/11b/11g/11bg/11n wlan scan -s <ssid> -c <channel> -t <bsstype> NoOption : full scan ssid : 32 strings(max) channel : 0-14 (0:Auto) bsstype : 1-3 1 : access point 2 : adhoc 3 : any scan wlan channel <channel> NoOption : display channel channel : 0-14 (0:Auto) channel wlan enc <mode> <key> <keystring> NoOption : display encrypt setting mode : 0-4 0 : Open 1 : WEP40 2 : WEP104 3 : WPA 4 : WPA2 key : 0-3 0 : index / TKIP 1 : index / AES 2 : index 3 : index keystring : encrypt key(max 63 strings) WEP40 : 5 character fixed(ascii) / 10 character fixed(binary) WEP104 : 13 character fixed(ascii) / 26 character fixed(binary) WPA : 8-63 strings WPA2 : 8-63 strings wlan ssid [ssid] NoOption : display ssid ssid : 32 strings(max) ssid wlan mac [macaddr] {-r} NoOption : dispaly MAC ADDRESS macaddr : MAC ADDRESS (XX:XX:XX:XX:XX:XX) {-r} : after MAC ADDRESS FlashROM save and reboot wlan start <channel> channel : 0-14 wlan slottime <0..7> 0: station 11a/n short slot 1: station 11g/n short slot 2: station 11g/n long slot 3: station 11b long slog 4: ap 11a/n short slot 5: ap 11g/n short slot 6: ap 11g/n long slot perf udp tx [ipaddr] <count> <size> {burst} perf udp rx ipaddr : X.X.X.X count : Xs/Xm/Xh/X (sec/min/hour/num) size : def/big/num (num<=14600) burst : Non-Blocking only cl : TCP client clnb : TCP client Non-Blocking sv : TCP server svnb : TCP server Non-Blocking cs : TCP client & server csnb : TCP client & server Non-Blocking wps credential {-c} <select> NoOption : display Credential {-c} : Credential clear select : 0-5 wps assoc <mode> NoOption : display Association mode mode : auto / manual wps pincheck <pin> NoOption : display PIN code pin : PIN code (8 character fixed) wps pin <pin> <ssid> pin : PIN code (8 character fixed) ssid : 32 strings(max) show help show reg -r <addr> show ch show mac show mep show time TELEC commands show stop help stop frame stop pn stop send frame -n <count> -i <interval> -s <sifs> -r <rifs> -e <enc> send pn -r <rate> -m <mcs> -p <preamble> -g <gi> setup frame -l <macl> -u <macu> -b <body> -s <size> -t <tid> -r <rate> -p <power> -a <ack> -m <mcs> setup ch -f <freq> -c <channel> setup reg -r <reg:hex> -v <val:hex> setup dump -m [mode] -f <fil> macsend r <rate> -c <cipher> -a <ack> -n <count> -t <tid> -h <channel> [macaddr:hex] rate : 0 auto 1/2/5/6/9/11/12/18/24/36/48/54 (Mbps) cipher : no/wep/aes/tkip ack : ack/no count : 1-65535 tid : 0-65535 channel : 1-14 macaddr : XX:XX:XX:XX:XX:XX MAC frame send macsend reboot system reboot ping [ipaddr] <count> <size> ipaddr : X.X.X.X count : 1-65535 size : 1-2920 ip [ipaddr] {mask [m_addr]} {gw [gw_addr]} NoOption : display ip setting ipaddr : X.X.X.X m_addr : X.X.X.X gw_addr : X.X.X.X stat <NoOpt/clear/stack> show status stat dump [addr] {-l length} (round 4byte) addr (hex) : 0xXXXXXXXX length(hex) : 0xYYYYYYYY mod [addr] [data:hex] {-l length:hex} (round 4byte) addr (hex) : 0xXXXXXXXX data (hex) : 0xYYYYYYYY length(hex) : 0xZZZZZZZZ print [onoff] onoff : on / off sleep {-bb <bb>} {-host <host>} {-rxen <rxen>} {-rfshdn <rfshdn>} {-deep <deep>} {-clk <clk>} bb : 0/1/2 0 : MAC layer reset 1 : MAC layer normal 2 : MAC layer clock stop host : 0/1 0 : host clock stop 1 : host clock normal rxen : 0/1 0 : RX control off 1 : RX control on rfshdn : 0/1 0 : RF control off 1 : RF control on deep : 1-65535 clk : 0/1 0 : External clock off 1 : External clock on factory -mac <mac address> -code <manufacture code> -f0 <Traceability-0> -f1 <Traceability-1> -agcuse <1:use, 0:Unuse> -agcdsss <ch1agc ch2agc..ch11agc> -agcofdm <ch1agc ch2agc..ch11agc> -agcofdm <ch1agc ch2agc..ch11agc> -tbase <ch1TSSIbase ch2TSSIbase..ch11TSSIbase> -toffset <DSSSoffset OFDMoffset MCSoffset> -e(erase information) -iquse <1:use, 0:Unuse> -txiq <OFDMI OFDMQ DSSSI DSSSQ> pw <bboff/bbon/anaoff/anaon/rfoff/rfon> ps [on/off] ftpscert [filename] ftpsdel [-p <port>] -m <mode> <address> <user> <password> <filename> mode: 0:Implicit 1:Explicit ftpsren [-p <port>] -m <mode> <address> <user> <password> <source> <destination> mode: 0:Implicit 1:Explicit ftpsls [-p <port>] -m <mode> <address> <user> <password> <directory> mode: 0:Implicit 1:Explicit ftpsput [-p <port>] -m <mode> <address> <user> <password> <server file> <local file> mode: 0:Implicit 1:Explicit ftpsget [-p <port>] -m <mode> <address> <user> <password> <server file> <local file> mode: 0:Implicit 1:Explicit ftpdel [-p <port>] <address> <user> <password> <filename> ftpren [-p <port>] <address> <user> <password> <source> <destination> ftp rename ftpls [-p <port>] <address> <user> <password> <directory> ftpput [-p <port>] <address> <user> <password> <server file> <local file> ftp upload ftpget [-p <port>] <address> <user> <password> <server file> <local file> ftp download nbios [opt] opt : start / stop / stat dhcpc [opt] opt : start / stop dhcpd [opt] opt : start / stop / stat level <arg> arg : NoOption : display mode setting 1048 : developer 2 : factory 1 : enduser
More info
05/01/2015 at 20:47 • 0 commentsfound some images of the board digging through google image search..
Chips are as follow:
Processor : TC90535XBG ?
Flash Memory : TC58NVG6D2GLAD0E ?
WIFI : AIROHA AL2238 wifi b/gI cannot read the others, but either way I was not able to find any details about the Processor or even the Flash Memory.
Also, with the help of a friend, I ran the update file through IDA Pro, and he said it appears IDA is detecting it as Armv6 code. We were not able to find the bootloaders load start. Although it may not be in the update file as it may not be a complete firmware image.. More is still needed to be researched, but I wanted to update this.
