After removing the battery, PC cards, speakers, LCD, and touch pad. I decided to remove the bottom half of the original case( I admit, I used a hacksaw) then I bent the middle frame to make space to reinstall the keyboard.
The whole project is electrical tapes togeather at the edges. I hope to make a case that's a little nicer in the future.
I also added a RCA and svideo out so it will adapt to just about any monitor.
I also hope to add a built in kvm switch so I can use it for work as well.
thatredbird
Daniel Nugent
Patrick Tait
andrew
Rob
