Currently there are two parts to this project. The first is to write the simulation software, and the second is to write a simple program to plot the outputs with reference to the input times.
A simulation of a basic pulsed neural network, just slightly different than a traditional neural network.
During my free time in the past few weeks I've worked on my code, so here's a semi-fleshed out skeleton of the code so far. It will also be on Github in the coming weeks. There's a couple of modifications to do, specifically, a better and more thorough plot of not just the neuron pulse times, but also the synaptic event times, and also the projected pulse time calculations need a little tweaking.
# Neural Network Model
# This program will simulate an event driven model of a pulsed neural network.
__author__ = 'JangoJungle'
from numpy import *
import random as rand
import matplotlib.pyplot as plt
# A quick function to get the synapse state form for plotting -- Not Used Yet
def get_state(w, t, a):
stateraw = Decimal(w - w * abs(t - a))
index = 0
for x in stateraw:
if x <= 0:
stateraw[index] = 0
index += 1
return stateraw
# declare/initialize variables
# other variables
next_event_time = 0
current_time = 0
fault = 9999999
count = 0
interval = linspace(0,49,50)
# synaptic variables
synaptic_weights = r_[[1, 1, 1]]
state_of_synapses = r_[[0, 0, 0]] # 1 for up, -1 for down, 0 for idle
synaptic_delays = r_[[rand.randint(0, 3), rand.randint(0, 3), rand.randint(0, 3)]]
synaptic_event_times = r_[[1, fault, 1]] # start the trigger and pulse train [pulse train, neuron output, trigger]
synapse_connection_matrix = r_[1, 1, 1]
# neuron variables
previous_activity_slope = r_[0]
current_activity_slope = r_[0]
threshold = 1.5
neuron_pulse_times = r_[fault]
neuron_connection_matrix = c_[[0, 1, 0]] # only one column: only one neuron, connected to synapse 2
pulse_points = linspace(0,0,50)
# Start loop:
while (count < 50):
# Go to next event time
current_time = next_event_time
# Calculate the Next Neuron firing time -- how to adjust this for multiple neurons?
current_activity_slope[0] = sum(state_of_synapses*synaptic_weights) + previous_activity_slope[0]
if current_activity_slope[0] > 0:
neuron_pulse_times[0] = threshold/current_activity_slope[0] + current_time
else:
neuron_pulse_times[0] = fault
previous_activity_slope[0] = current_activity_slope[0]
# Find the next event time and type
next_synapse_event_time = min(synaptic_event_times)
next_synapse = argmin(synaptic_event_times) # note: argmin returns a 1d index
next_neuron_firing_time = min(neuron_pulse_times)
next_neuron = argmin(neuron_pulse_times)
next_event_times = r_[[next_synapse_event_time, next_neuron_firing_time]]
next_event_time = min(next_event_times)
event_type = argmin(next_event_times) # 0 for synapse, 1 for neuron
# Do required operations for each event type
if next_event_time != fault:
# If it's a synapse event time, update the states
if event_type == 0: # synaptic event == 0
# Update states
if state_of_synapses[next_synapse] == 0:
state_of_synapses[next_synapse] = synaptic_weights[next_synapse]
synaptic_event_times[next_synapse] += 1
print ('Synapse {} is firing.'.format(next_synapse))
elif state_of_synapses[next_synapse] == synaptic_weights[next_synapse]:
state_of_synapses[next_synapse] = -synaptic_weights[next_synapse]
elif state_of_synapses[next_synapse] == -synaptic_weights[next_synapse]:
state_of_synapses[next_synapse] = 0
synaptic_event_times[next_synapse] = fault
# reset the pulse train if it's the pulse train
if next_synapse == 0:
synaptic_event_times[next_synapse] = (2 + current_time + synaptic_delays[next_synapse])
# If it's a neuron firing time, reset the synapses, find all the synapses this neuron is connected to
# and then update those synapses
if event_type == 1: # neuron firing = 1
print ('Neuron is firing.')
# reset synapses
state_of_synapses[0] = state_of_synapses[1] = state_of_synapses[2] = 0
synaptic_event_times[0] = synaptic_event_times[1] = synaptic_event_times[2] = fault
# find all the synapses this neuron is connected to and update them
connected_synapses...
Thank you! And thanks Bruce Land for the links! Looks like you're heading the direction I want to go with this: Hardware. That's great! Good work!
