Version B prototype
A project log for Hardware password manager
Small USB unit which simulates keyboard and generates, keeps and types up to eight passwords
voja-antonicVoja Antonic 08/17/2015 at 14:388 Comments
My PCBs arrived at last, so I can build the final prototype, with much simpler hardware.
The main modification is in True RNG hardware - istead of external white noise generator, which also worked fine, now I use the uninitialized internal RAM state. I described that process at http://hackaday.com/2015/06/29/true-random-number-generator-for-a-true-hacker/, so I won't write about it here.
I have built six units (that much I promissed to my friends), and everything works great. Here is the first photo:
Rich text editor
deʃhipu wrote 11/23/2015 at 08:29 point
Those orange PCBs look very nice! Where did you find them?
Voja Antonic wrote 11/23/2015 at 08:36 point
Ordered from Accredo, but most suppliers offer different colours today.
deʃhipu wrote 11/23/2015 at 09:29 point
They sure do, but I've never seen orange ones.
lond wrote 11/22/2015 at 12:54 point
Hi!
When I try to build I get four warnings:
Warning[202] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 521 : Argument out of range.  Least significant bits used.
Message[311] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 735 : Operand of HIGH operator was larger than H'FFFF'.
Warning[202] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 774 : Argument out of range.  Least significant bits used.
Warning[202] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 779 : Argument out of range.  Least significant bits used.
The build produce a HEX-file, but the password listing function doesn't work :(
/// Marcus
Voja Antonic wrote 11/22/2015 at 13:02 point
Yes, it's because the default radix is hex.
If you use MPLAB (not MPLABX), then try this:
Project/Build Options/Project/MPASM Assembler, then check
Disable Case Sensitivity, and Default Radix = decimal
If you use MPLABX, find the equivalent to preset default decimal
lond wrote 11/22/2015 at 13:14 point
Tanks!
Now it's working :D :D
/// Marcus
Voja Antonic wrote 11/02/2015 at 10:07 point
Sorry, memory error in my head :) Now it's there
http://www.voja.rs/PROJECTS/Password%20Manager/0_intro.htm
You can select RNG type and MCU type at the beginning of the source file.
Default is "software RNG" and "PIC18F24K50"
Damian wrote 11/02/2015 at 06:14 point
Will source files be released for version B at some stage?
