The EMDrive V4 got a modification.
I inserted a 3D-printed dielectric on the big end - which showed significant performance boost in another (not my) test on a 900 MHz thruster.
I recorded a 5 values/s sweep from 22.5 GHz to 25.5 GHz without dielectric and I´m just now recording the same sweep wiith the dielectric inside. I will post the data when it´s finished.
Ok, here is the comparison no_dielectric/with dielectric
Add. Info: Curve is named "Sensor", it´s arctan(IFQ/IFI), but it´s just the ADC values, so there is an overall characteristic which the curve is not normalized to.
In case you complain about not labeled axes again ;)
Great results! You can also consider a piece of glimmer or mica as dielectric. As glimmer is a package of sheets that are easy detachable , you can experiment with different layer thicknesses. You can find glimmer in old heaters.. High power condensers still use it as dielectric.
If you got the chance, could you redo the test with a dielectric made of PTFE or HDPE? Thanks again!
And when do I sleep? I think I´ll run more tests on ABS and will meanwhile prepare the PocketQub.
Good work! Can you tell us what material you are using for your dielectric? Thanks!
It´s 3D-printed with ABS, 3mm thick
Thanks! Was it with full infill settings?
