A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
How does your "reverse" setup look like?
And is the overall thickness of the dielectric a issue?
Reverse just means that the cavity is turned in the opposite direction.I just tried the 3mm dielectric, but the thickness probably will be of importance
did you try some glimmer already? you can make this as thick as a sheet of paper..
Yes, delete it Cancel
