24 GHz source working
05/23/2015 at 14:25 • 0 comments24 GHz modification of a radar module for our BabyEMdrive.
I removed the patch antenna connection to the via and soldered an antenna connector.
The freakin expensive blue cable can deliver up to 26 GHz with low loss.Signal on the Osci: Doppler frequency from the mixer output
Jo made the cavity
05/21/2015 at 18:32 • 2 commentsJo finished the machining of a 24 GHz cavity today.
Look at this wonderful piece. We will be able to make a test soon. -
Jo starts machining
05/15/2015 at 07:30 • 0 commentsJo cuts the block which will become our 25 GHz cavity soon.
