All constructive details are visible on photos and drawings. The mechanical base is mainly made off melamine faced chipboards and FR4. Acryl platten holder is mounted on linear bearing, which is driven by stepper motor and controlled by microprocessor. The only operation which the operator has to do during the scanning process,is to turn the page of the book and to press the Start key. It will initiate the next sequence of steps:
- Acryl platen moves in the lowermost position and presses the pages by its weight
- LED lighting is forced to full power (12 LEDs x 1 W)
- Remote shooting is activated
- LED lighing is lowered
- Acryl platen moves back to upper (home) position
On the top of the book scanner, there are four sticks, used as holders for black cloth blinds, to avoid light reflection on the platen.
Voja Antonic
jackw01
Akos Sereg
Roman
sexy killer project!
Mark II wish list:
-arduino w/relay shield
-12vdc power supply
-small vacuum pump
-pick and place suction cup/needle
-solenoid valve
-cheap servo motor
-small dc motor w/rubber wheel
-wooden dowel w/ weak spring
