OSH Park board link
05/22/2015 at 18:56 • 0 commentsYou can order the board from here:
Library update required
05/09/2015 at 16:12 • 0 commentsYou need to modify the Adafruit_SI1145 library as follows (or just substitute tthe SI1145 for the SI1132):
edit Adafruit_SI1145.cpp
#include "Adafruit_SI1145.h" Adafruit_SI1145::Adafruit_SI1145() { _addr = SI1145_ADDR; } boolean Adafruit_SI1145::begin(void) { Wire.begin(); uint8_t id = read8(SI1145_REG_PARTID); // if (id != 0x45) return false; // look for SI1145 if ((id != 0x32) && (id != 0x45)) return false; // look for SI1132 or SI1145
