1Print it.
Settings I used are in the description. Basically strong along the X/Y axis, not as much in Z, as hollow as you can get without bridges getting fussy.
2Trim the shaft area.
The shaft area has supports built into the model, so slicers 'do the right thing'.
Trim with a razor.
MasterOfNull
