Inexpensive function generator
An open source inexpensive function generator
The device is an open source, inexpensive, Direct Digital Synthesis functiongenerator. The device is aimed to be used as a stand alone device, or as amodule in a larger circuit. The primary aim of the device is to offer reasonableperformance at a very low cost, allowing it to be a tool for anyone doingelectronics related things.Specifications:• Single 12 V DC supply required• 10 MHz output (limited at 20MHz)• Sine, triangle and square waveforms available• 10 V p-p amplitude• +/- 5 V DC offset• 50 Ohm output• Logic level square wave output• External control via serial port• External control of voltage parametersTindie kit:https://www.tindie.com/products/untemed/10-mhz-function-generator-diy-kit/
Motivation
For a long time I've been looking for a inexpensive function generator that can perform well in the MHz range. I tried getting various modules from ebay but all of them ended up with disappointment due to lacking performance.
So the only thing left to do is to design one from scratch with the specs I wanted and with the price that is on par with what can be bought from China.
The goal of the project is to make a open source function generator with features that would make it a actually useful device for hackers and makers with a price so that that anyone can afford to buy/make one. The device is meant to be very versatile, so it can be used in various applications as well as a module in a larger system (hack friendly).
Project purpose
There are a lot of function generator kits available online, but all of them some sort of problem.
Usually they are low bandwidth or just too expensive for what a beginner maker might be able to afford.
Having something that with a 20$ BOM or less makes it within reach for even the beginner makers giving them a tool that they will be able to use for quite a while.
Being open source also means that the the firmware can be modified and since all of the useful internal signals are exposed it can be used as a module without the screen and potentiometers making it hacker friendly. Another benefit is that anyone could build it from scratch and improve it contributing to the project as any other open source project.
Parts used
- AT89C51, it is good enough for the job, and also very cheap reducing the BOM
- AD9834 DDS IC, reasonably cheap and offers most of the functionality required
- AD811 opamp, also very cheap on ebay with enough bandwidth for the output amplifier, tho I will try to replace it with the AD8021 so I can reduce the dependency from sourcing parts from Chinese suppliers
- MC34063 to generate the -12V rail
- LM324 to handle the amplitude and DC offset controls
- 74HC4053 to generate the square wave signals
- 1602 LCD
Once the current design is completed, I'm maybe going into looking how to cut costs even down starting with replacing the DDS ic with a low cost FPGA which will enable many new features.
Block diagram of the current circuit:
Connector pinout
Portable Network Graphics (PNG) - 511.89 kB - 07/11/2018 at 23:54
Preview
DDSFG-manual.pdf
User manual
Adobe Portable Document Format - 874.25 kB - 07/11/2018 at 23:53
Preview
funct_gen_v1.0.zip
KiCad project
x-zip-compressed - 1.36 MB - 07/07/2018 at 18:49
Download
Function_Gen_source.zip
Code Blocks project for the firmware. Uses the SDCC C compiler.
x-zip-compressed - 84.83 kB - 07/07/2018 at 18:28
Download
Instead of the 89C51 the ATmega328 can be soldered instead under the 89C51 footprint, this picture shows the wiring.
Portable Network Graphics (PNG) - 61.04 kB - 05/19/2018 at 22:05
Preview
View all 8 files
  • V1.0 PCBs arrived
    DL101 • 08/08/2018 at 19:39 • 0 comments
    The v1.0 PCBs are here!
    You can purchase the v1.0 kit on the tindie page.
  • Tindie kit
    DL101 • 07/16/2018 at 11:38 • 0 comments
    There is now a tindie kit available for purchase of the v0.4 prototype.
    At the moment I only have the leftover parts from the prototypes, but I ordered more parts and new boards so I can have more kits in stock.
  • User manual
    DL101 • 07/12/2018 at 13:18 • 0 comments
    I've wrote a user manual on how to operate the device once in its original form Link.
  • Project files released
    DL101 • 07/07/2018 at 18:50 • 0 comments
    I've finished doing various bug fixes, so now the files have been published.
    The next step is to write s user manual.
  • Bugs
    DL101 • 07/02/2018 at 15:15 • 0 comments
    I've found a few minor bugs with the firmware that need to be fixed.
    Once that is done I'll do a minor PCB revision with only layout changes.
    When I'll have everything completed and fixed I'll publish the project files.
  • Firmware first version completed
    DL101 • 06/20/2018 at 01:29 • 0 comments
    I've completed the first version of the firmware with the basic functions and frequency sweep.
    Unfortunatly only about 140b of program memory is left so there isn't much space to add more features without upgrading
    the mcu.
  • v0.4 completed
    DL101 • 05/19/2018 at 21:42 • 0 comments
    I got the v0.4 pcb-s and soldered the parts and it works!
    Everything now works as it should, all the voltages are matching as they should (previous version had some offsets).
    Now the only thing left is to finish the firmware (and find two 100 ohm resistor somewhere).
    Also the knobs are a bit large, so I'm looking for alternatives on ebay to replace them so the scale on the pcb is more visible.
  • v0.3 completed
    DL101 • 05/10/2018 at 00:27 • 0 comments
    I finished with the v0.3 and it works with a few minor bodges.
    Now I'm about to order the v0.4 which should hopefully be the final version with the final modifications.
  • v0.3 PCB ordered
    DL101 • 04/11/2018 at 13:00 • 0 comments
    I finished routing the v0.3 PCB and ordered it.
    Now it can also use the ATmega328 instead of just the 89C51.
  • v0.3 Schematic
    DL101 • 04/08/2018 at 18:26 • 0 comments
    I managed to add square waves to the output waveform types with a 74HC4053 without affecting the price too much.
    Now I have to make a new PCB and test it out.
    Link: Schematic
View all 17 project logs
Yann Guidon / YGDES wrote 02/18/2018 at 16:35 • point
I'm curious about the jitter, which is a big issue with a DDS.
DL101 wrote 02/18/2018 at 23:54 • point
The datasheet of the DDS puts it at: 120 ps rms 3 MHz sine wave
Yann Guidon / YGDES wrote 02/18/2018 at 23:58 • point
nice but it should be measured for many frequencies :-)
particularly frequencies that are relatively prime to the main clock :-)
Then again it also depends on your requirements.
DL101 wrote 02/20/2018 at 21:22 • point
I can go to the local uni and borrow the lab to do measurements once its done, but I can't do miracles without increasing the bom. The point of this is to have something good enough for most common applications.
Ted Yapo wrote 02/19/2018 at 00:11 • point
If the title were "Low Phase Noise Function Generator," I'd agree that it requires measuring.  As it is "Inexpensive Function Generator," I'm willing to trust the good people at Analog Devices. :-)
DL101 wrote 02/20/2018 at 21:23 • point
Yes, I'll try to make is as good as I can without increasing the bom.
