1Overview
I will be cutting up and taking apart bicycle frames, welding them together.
4 batteries will be connected via series. The other 4 will be connected via parallel. batteries will be mounted on the front panel of the frame.
The motor will be mounted to back plate of the frame, and chain linked to the rear wheel.
Controller will mounted along the front side of the frame, motor and throttle will be connect-one speed.
Jack Dudich
