The following sensors have been ordered and will be used for development. They each have their own way of detecting conditions that may indicate Peril.
Temperature sensor - sudden shifts of temperature up or down may indicate Peril Pulse sensor - a rise in pulse rate may indicate stress, therefore Peril Ambient Light sensor - sudden shifts in light levels (sudden darkness, sudden light) may precede Peril Sound Detector sensor - sudden loud noises or a sudden sound when there was previously silence may indicate Peril - (TBD) Galvanic Skin Response - can be built from workbench supplies if needed. Skin conductivity increases when sweat glands activate, due to stress. Good indicator of actual or subconscious Peril.
- Accelerometer - to detect sudden movements; sudden movement on the wearer's part is a pretty good indication of Peril. (Added 2014-04-07)
