- I should compare the pinouts of my FTDI dongles, they seem to be different on RX vs. TX
- the pin holes for the ESP-01 version are way to tight
- I might add another 10uF cap near to the ESP module
- USB micro footprint for 5V in ?
A project log for Ignore this ESP8266 board
I stole from every one. The huzza from Adafruit. Matts breakout board. Al1s board from here. NodeMCUs DevKit.
YES, micro USB footprints EVERYWHERE! And how about an optional CH340G footprint to omit the problem of different pinouts of different USB2serial dongles? I personally prefer the CP2102.
I'm not so sure about the serial chips, because of all the options etc. so maybe this project of @al1 would be interesting for you then?
https://hackaday.io/project/5231-esp8266-esp-0712-dev-board
Yeah, I've seen his board but I think I got deterred by the mini USB ;) But maybe I'll bug him until he switches to micro USB ;)
I just figured if you add USB you might as well add the footprint for a serial chip while still keeping the serial header.
I'm not sure if the ch340g is working with OSX - I think that's why I skipped that.. I have to check the footprints of mini and micro usb ports, maybe they are quite alike and there is a dual footprint. I could not find a micro usb footprint in my libraries...
dual foot print for micro and mini USB sounds like a good Idea. I shuold add that to my todo list.
this way @Stefan Lochbrunner would be happy too :)
very happy :)
Hey @al1, would you mind connecting DTR/CTS?
correction: it's DTR and RTS for ESPtool and NodeMCU devkit
I have stated to think about a next revision of my PCB. There I will use both micro and mini USB. And also I will try to get optional compatibility to the nodeMCU boards. Check ouzt my project log there will be (maybe tomorrow or after my vacation - at the end of august) a new log entry about this new revison.
looking forward to it, have a good time on your vacation!
