some notes
A project log for Ignore this ESP8266 board
I stole from every one. The huzza from Adafruit. Matts breakout board. Al1s board from here. NodeMCUs DevKit.
davedarkodavedarko • 08/04/2015 at 20:38•9 Comments
Stefan Lochbrunner wrote 08/04/2015 at 20:48 • point
YES, micro USB footprints EVERYWHERE! And how about an optional CH340G footprint to omit the problem of different pinouts of different USB2serial dongles? I personally prefer the CP2102.
davedarko wrote 08/04/2015 at 21:04 • point
I'm not so sure about the serial chips, because of all the options etc. so maybe this project of @al1 would be interesting for you then?
https://hackaday.io/project/5231-esp8266-esp-0712-dev-board
Stefan Lochbrunner wrote 08/04/2015 at 22:46 • point
Yeah, I've seen his board but I think I got deterred by the mini USB ;) But maybe I'll bug him until he switches to micro USB ;)
I just figured if you add USB you might as well add the footprint for a serial chip while still keeping the serial header.
davedarko wrote 08/05/2015 at 04:18 • point
I'm not sure if the ch340g is working with OSX - I think that's why I skipped that.. I have to check the footprints of mini and micro usb ports, maybe they are quite alike and there is a dual footprint. I could not find a micro usb footprint in my libraries...
Alex wrote 08/05/2015 at 07:16 • point
dual foot print for micro and mini USB sounds like a good Idea. I shuold add that to my todo list.
davedarko wrote 08/05/2015 at 07:36 • point
this way @Stefan Lochbrunner would be happy too :)
Stefan Lochbrunner wrote 08/05/2015 at 11:43 • point
very happy :)
Hey @al1, would you mind connecting DTR/CTS?
correction: it's DTR and RTS for ESPtool and NodeMCU devkit
Alex wrote 08/13/2015 at 20:28 • point
I have stated to think about a next revision of my PCB. There I will use both micro and mini USB. And also I will try to get optional compatibility to the nodeMCU boards. Check ouzt my project log there will be (maybe tomorrow or after my vacation - at the end of august) a new log entry about this new revison.
davedarko wrote 08/13/2015 at 20:48 • point
looking forward to it, have a good time on your vacation!
