1Step 1
Assemble the Hardware like described in the video. Afterwards download the latest FabScanPi Raspbian Image ( from fabscan.org) and flash it to the SD-Card.
2Step 2
Insert the SD-Card to your Pi. Then connect your FabScanPi to your local network (router or switch) and also connect the 12V power supply.
3Step 3
After the Pi is booted you can point your browser to
http://[ ip-address-of-your-raspberry-pi ]
Hint: If you have zeroconf compatible Laptop or Tablet ( e.g. Apple's Bonjour) you can find your FabScan Pi setup by pointing your browser to http://fabscanpi.local
Happy scanning!
4Step 4
For full instructions visit the docs at GitHub pages: http://mariolukas.github.io/FabScanPi-Server/
Mario Lukas
