Low profile
08/17/2015 at 16:44 • 0 commentsWe will be using the Molex 504077-1891 in our Edison FM as well. The profile is low enough to fit under the Edison.
Better pricing
08/17/2015 at 16:41 • 0 commentsWe found a lower cost source recently for these and will be buying a moderate quantity.
Updated solder bridge
08/17/2015 at 16:40 • 0 commentsThe CD solder bridge has been updated for a 10mil spacing. This should allow for easier shorting while still removable.
SPI testing
08/17/2015 at 16:39 • 0 commentsWe have tested this board with SPI and it seems functional.
