1Step 1
Connect your BUS MOUSE pins to the following pins of your Arduino Pro Micro:
- Gnd : Ground
- Vcc : Vcc (+5V)
- Port D3 : X axis encoder / channel A
- Port D2 : X axis encoder / channel B
- Port D1 : Y axis encoder / channel A
- Port D0 : Y axis encoder / channel B
- Port B3 : Switch 1
- Port B2 : Switch 2
- Port B1 : Switch 3
2Step 2
Upload the following sketch to your Arduino Pro Micro using the Arduino IDE (I used the 1.6.7 version for this code):
#include <Mouse.h> /* ================================================================================ Author : GuilleAcoustic Date : 2015-05-22 Revision: V1.1 Purpose : Opto-mechanical trackball firmware -------------------------------------------------------------------------------- Wiring informations: Sparkfun Pro micro (Atmega32u4) -------------------------------------------------------------------------------- - Red : Gnd | Pin: Gnd - Orange : Vcc (+5V) | Pin: Vcc - Yellow : X axis encoder / channel A | Pin: PD3 - (INT0) - Green : X axis encoder / channel B | Pin: PD2 - (INT1) - Blue : Y axis encoder / channel A | Pin: PD0 - (INT2) - Violet : Y axis encoder / channel B | Pin: PD1 - (INT3) - Grey : Switch 1 | Pin: PB3 - White : Switch 2 | Pin: PB2 - Black : Switch 3 | Pin: PB1 -------------------------------------------------------------------------------- Latest additions: - 2016-01-28: Software switch debouncing ================================================================================ */ // ================================================================================= // Type definition // ================================================================================= #ifndef DEBOUNCE_THREASHOLD #define DEBOUNCE_THREASHOLD 50 #endif // ================================================================================= // Type definition // ================================================================================= typedef struct ENCODER_ { int8_t coordinate; uint8_t index; } ENCODER_; typedef struct BUTTON_ { boolean state; boolean needUpdate; char button; byte bitmask; long lastDebounceTime; } BUTTON_; // ================================================================================= // Constant definition // ================================================================================= const int8_t lookupTable[] = {0, 1, -1, 0, -1, 0, 0, 1, 1, 0, 0, -1, 0, -1, 1, 0}; // ================================================================================= // Volatile variables // ================================================================================= volatile ENCODER_ xAxis = {0, 0}; volatile ENCODER_ yAxis = {0, 0}; // ================================================================================= // Global variables // ================================================================================= BUTTON_ leftButton = {false, false, MOUSE_LEFT, 0b1000, 0}; BUTTON_ middleButton = {false, false, MOUSE_MIDDLE, 0b0010, 0}; BUTTON_ rightButton = {false, false, MOUSE_RIGHT, 0b0100, 0}; // ================================================================================= // Setup function // ================================================================================= void setup() { // Attach interruption to encoders channels attachInterrupt(0, ISR_HANDLER_X, CHANGE); attachInterrupt(1, ISR_HANDLER_X, CHANGE); attachInterrupt(2, ISR_HANDLER_Y, CHANGE); attachInterrupt(3, ISR_HANDLER_Y, CHANGE); // Start the mouse function Mouse.begin(); } // ================================================================================= // Main program loop // ================================================================================= void loop() { // Update mouse coordinates if (xAxis.coordinate != 0 || yAxis.coordinate != 0) { Mouse.move(xAxis.coordinate, yAxis.coordinate); xAxis.coordinate = 0; yAxis.coordinate = 0; } // --------------------------------- // Left mouse button state update // --------------------------------- ReadButton(leftButton); UpdateButton(leftButton); // --------------------------------- // Right mouse button state update // --------------------------------- ReadButton(rightButton); UpdateButton(rightButton); // --------------------------------- // Middle mouse button state update // --------------------------------- ReadButton(middleButton); UpdateButton(middleButton); // Wait a little before next update delay(10); } // ================================================================================= // Interrupt handlers // ================================================================================= void ISR_HANDLER_X() { // Build the LUT index from previous and new data xAxis.index = (xAxis.index << 2) | ((PIND & 0b00000011) >> 0); xAxis.coordinate += lookupTable[xAxis.index & 0b00001111]; } void ISR_HANDLER_Y() { // Build the LUT index from previous and new data yAxis.index = (yAxis.index << 2) | ((PIND & 0b00001100) >> 2); yAxis.coordinate += lookupTable[yAxis.index & 0b00001111]; } // ================================================================================= // Functions // ================================================================================= void ReadButton(BUTTON_& button) { // Variables long currentime; boolean switchState; boolean debounced; // Get current time currentime = millis(); debounced = (currentime - button.lastDebounceTime > DEBOUNCE_THREASHOLD); // Get current switch state switchState = !(PINB & button.bitmask); // Button state acquisition if ((switchState != button.state) && debounced) { button.lastDebounceTime = currentime; button.state = switchState; button.needUpdate = true; } } void UpdateButton(BUTTON_& button) { if (button.needUpdate) { (button.state) ? Mouse.press(button.button) : Mouse.release(button.button); button.needUpdate = false; } }
DENIS Guillaume
