Pinout for the pump side
02/01/2014 at 04:47 • 0 commentsTIP is B (SIGNAL), RING is A (12V), SHIELD is GND
In my cable that's Black for B and Brown for A. Shield for Shield, duh.
German Engineering
02/01/2014 at 04:42 • 0 commentsLeave it to zee germanz to completely overengineer what should have been a simple UART interface.
I hooked up the UART <> USB adapter and tried all kinds of pinouts, it simply wouldn't work. I tried measuring the interface with the bus pirate and a multimeter but the readings didn't make sense for a UART port.
So ... after some digging I realized that this is not a UART port but RS485. It's a robust 3 wire connection based on voltage differentials. The upside is that it allows for very long cables, whoever might care about that in this setup. It's also commonly used for Alarm Panels in home alarm systems. Just FYI. Also fun to play with.Anyway... My only RS485 adapter is in permanent installation in said alarm system so I need to get a new one, or better yet, just get a USB <> RS485 interface.
This is getting more complicated than I thought. No biggie though. Next week this should be done. I need to look into UART <> RS485 interface options if I want to control this thing from an Arduino or Raspberry Pi.
What we know so far ...
01/28/2014 at 06:45 • 0 comments1. The eheim software itself has a firmware update button, but it links to a defunct php script on their site, so it doesn't work. They no longer supply firmware updates to users, you can send in your pump head (yeah, right) or you can use a third party software from "GHL", a company that eheim seems to have an agreement with about distributing the firmware at their (GHL's) risk.
2. I found the manual for the GHL updater and the filenames of the firmware indicate that the pump is controlled by a PIC18F252. This might be handy to know down the road.
3. The manual also indicates that the PIC is using some kind of bootloader and there is a application note for a bootloader for this PIC on the Microchip site. Maybe eheim just re-used the code. Something to poke at later.
