Patterns are generated on the fly by SmartMatrix and can be customized by selecting a color palette to match your decor or mood. Over 32 patterns are built into SmartMatrix.
Audio patterns react to music connected via a headphone-style cable. Cycle through the included patterns along with your favorite color palette. Connect SmartMatrix to the line-out port of your stereo or sound card, or use a Y-adapter to tap into the signal between your audio source and speakers.Play 32x32 pixel GIF Animations on SmartMatrix. Find, convert or create your own 32x32 pixel GIF with any software that outputs GIF files and drag it to the SmartMatrix USB drive to add new animations. It's quite easy to use free online tools to convert large videos and GIFs into 32x32 pixel size.
On top of any content (Patterns, Audio Patterns, Animations), you can display a clock or scrolling message. A built in Real Time Clock module keeps track of the time, with battery backup to keep time even when unplugged.
Louis Beaudoin
datagod
mircemk
icstation
ElecLab
So is there a difference between the kickstarter project and the Hackaday Store kit besides that the Hackaday kit requires soldering for assembly?
