64x32 RGB LED Matrix Bare Metal Tetris.
Video:
Kernel7 binary https://drive.google.com/file/d/0B6QxbmaAgfWLX2dXX05Udnh4TTA/view?usp=sharing
It does have sound, it will loop the GameBoy Tetris theme forever if you care to listen to it.
A bare metal Tetris game on a 64x32 RGB LED matrix, run by a Raspberry Pi 2 Model B.
Video:
Raspberry PI GPIO Wiring
SNES/NES controller
Connect SNES/NES 5V to RPI 3.3V (NOT 5V!)
Connect SNES/NES GND to RPI GND
Connect SNES/NES Clock to GPIO 2
Connect SNES/NES Latch to GPIO 3
Connect SNES/NES Data to GPIO 4
RGB LED Matrix:
Connect ADDRESS A to GPIO 5
Connect ADDRESS B to GPIO 6
Connect ADDRESS C to GPIO 13
Connect ADDRESS D to GPIO 19
Connect R1 to GPIO 10
Connect G1 to GPIO 09
Connect B1 to GPIO 11
Connect R2 to GPIO 25
Connect G2 to GPIO 08
Connect B2 to GPIO 07
Connect Enable to GPIO 16
Connect Clock to GPIO 20
Connect Latch to GPIO 21
Connect ALL LED Pannel GNDs via header to RPI GPIO GNDs, you should have 3 (Trust me, the more you have, the less flicker and glitches you will have with the LED Matrix.) (And don't bother with connecting the GND from the PSU to a RPI GPIO)
Check your wiring before powering up.
Hi, the img file doesnt work, do still have the code?
