EXCEL analysis software now added
04/18/2018 at 22:58 • 0 commentsThe project software folder now includes an Excel application that will accept the SD card data from the mapping module and produce CSV files to suit Garmin, Google Earth, or GPSVisualizer displays. A supporting document outlines basic setup and operation.Files for GPSVisualizer displays allow use of chosen markers and colors for your points, a feature the CSV parser on Google Earth does not support. The VBA code within the workbook is not locked so you can modify this application as you wish.
Three years field use, no changes needed
04/16/2018 at 20:00 • 0 commentsAfter three years of field use, this project's Arduino software has not needed any modification. The membrane keypad failed quickly, and was replaced with an identically faced click-buttton type which has performed faultlessly:-
Some features of the accompanying Excel based spreadsheet were found to be unnecessary, and the main function of converting the SD data from the Arduino into Garmin POI files was the mostly used function.
The original Excel spreadsheet was not released with this project and I am now preparing a version suitable for public release, which will enable the primary function of
preparing Garmin POI files from the SD data produced y the GPS.
peter ward
