1Find a filter that covers the fans
In principle, the hepa filter will be responsible for purifying the air from harmful dust. Of course I didn't find a filter with dimensions matching my case, but I found one that can be customized. I bought hepa filters for a small air purifier. About one and a half filters will fit into my case.
2Additional fan
I installed an additional fan to increase the filtering surface and the amount of cold air flowing. Previously, I had only one.
3Adjust the filters
4Additional filter
An additional filter will be useful, which will stop the big dust so that the hepa filter does not clog too quickly. Initially, I put a stocking on the filter. It wasn't bad ;) But I decided to buy a cotton filter. The cheapest was for the vacuum cleaner. It can be taped to the case. I chose a more aesthetic solution and I've used a 3D printed frame that hold all filters together.Frame and filters (I used only the black one):
And all together:
5Final touch
Now mount the filter in the desktop case.
On the left: a case with a dedicated anti-dust filter. It looks professional, but it's just a plastic and mesh.
On the right: the new filter is mounted.
