The resistor values are as follows:
- LED current limiting resistor = 1K
- Pushbutton switch pullup resistor = 1K
- Voltage divider resistors = 1K (top), 1.8K (bottom)
You can connect FTDI TX to ESP RX directly if you have a 3.3V FTDI.
Source code is at:
https://github.com/hwiguna/g33k/tree/master/ArduinoProjects/2015/_Done/110-One_way_Chat
hi harry,
i want to make this. can you share me the code? tks
