1Step 1
configuration of wifi is next
iface wlan0 inet static
address 192.168.1.101
netmask 255.255.255.0
network 192.168.1.0
gateway 192.168.1.254
wpa-ssid INFINITUM4A1D1F
wpa-psk 00E833BB44
--- issue on apache2
It was issue on apache2 so I decide to conect with cable temporaly.
2Step 2
I inspaired of tinkernut and based on it for this project(part of raspberry pi cluster).
http://www.tinkernut.com/2014/05/make-cluster-computer-part-2/
3Step 3
yesterday, 11 Jun 2015, I had a issue.
Cluster turned off after 3 days to work. Just one of top raspberry pi.
I think that it just a issue of dispel because the fan not cover first one of top. so I will improve new designe.
4Step 4
30 Jun, I designed again of cluster that cooling fan can cover all of four RPi(and very close) to avoid over heat and turn off.
