Here is the video from the last test, there is an offset to the right due to mis positionning of the support.
Also you can notice the limit of my current calibration for the heigh !
Zoom was disable and servo speed was a little bit to high, I hope the 10Hz GPS will improve the smoothing.
Hi, this really looks promising. Now that soloshot seems to be dormant.... How far in are you with the project.. Did you develop it further?
Très excitant de le voir suivre votre avion! This is great. Looking forward to seeing how the faster GPS translates, but already you are so close to smooth operation!
