PCB Redesign
A project log for Tote
Affordable spider robot
dehipudeʃhipu • 06/26/2015 at 11:39•0 Comments
After the recent failures and after using the Tote's PCB in a couple of different projects, I decided that some changes are needed to the design. Here is the new PCB:
There are several changes compared to the previous one:
Don't worry, the old board will not stop working, and I will still support it. The changes are not that big anyways -- I made sure that I don't change any pin numbers or anything similar, which would make the software incompatible.
I haven't ordered the new boards yet, so there is no link for ordering them. I will wait a couple more days for ideas for more improvements, and then order them.
