First try with an interactive floor.
06/01/2015 at 19:09 • 0 commentsIt is possible to measure the pressure piezo- element and a zener-diode. In first experiments it worked quite well.
The idea is to use a piezo element every 25 cm makes more or less 140 piezos. To get the data i used a MCP3008 a 8 channel analog spi interface. Then the floor looks like that:
To get it well i need 2 thin and strong layers - one underneath the sensor and one above.
In this test case I used acrylic glass with 8 sensors and one mcp3008. The problem is the weight and the cost of acrylic glass. Further ideas welcome.
nanu
