Hey there,
I finished the layout! I also updated the screenshots here in the gallery :)
I also revisioned the schematic so to remove any warning the ERC reported and added some copper pours on the PCB for power signals. Now I will just double check the PCB, to see if I could optimize the pours (I don't like empty board room).
As you can see there's some space left on the board, I may add an LED somewhere on the board (you know, for the classic Blinky test) and I will surely add a JACK logo somewhere. I could also do that on copper (!) because etched copper is way more precise than silkscreen, and looks neater!
After this last check, it's order time! .\m/
Cheers, Mick
PS: as always, check the Github page for the latest files.
