Layout in progress (crucial components done)
A project log for JACK
just another cortex kit - Cortex M0 development kit with an Atmel SAM D21, a USB device port, an LDO, some passives and breakout headers
michele-perlaMichele Perla 07/04/2015 at 18:310 Comments
Hey there,
After a week or so (read: after passing 10 minutes a day, for real) of work I managed to layout the most sensitive components of the circuit, that are in order of layout:
I want to keep a 1 inch spacing between the two headers, but placing the USB connector centered on the left side of the board forced me to put the chip a bit off from the center of the board, which in turn led me to "push" the upper breakout header up of 0.1 inch (to leave room for the crystal). I'll fix this by moving the clock a bit to leave just the right space.
The tricky part now is mapping the pins in a convenient way, that is so to have the less distance between chip pin and header pin to ease the layout process; also, I need to take extra care of the analog power signals so to avoid any noise in them.
