1Step 1
Program CNC
This is the general Machine-Operations set that was used to create the release candidate:
CNC parts
- G-code
- body
- back
- T2 roughing
- profiles
- roughing
- back cover
- e cavity
- T3 ball
- parallel surface
- set 1
- set 2
- parallel surface
- T4 detail
- seats
- bolt holes
- T2 roughing
- front
- T2 roughing
- switch cut
- roughing
- e cavity
- cavity clean
- final profile prep
- T3 ball
- parallel surface
- set 1
- set 2
- parallel surface
- T4 detail
- bolt holes
- edge
- T2 roughing
- back
- neck
- flat side
- T1 surfacing
- conventional surfacing
- T2 roughing
- body edge
- head edge
- T3 ball
- heel slopes
- T4 detail
- fork pocket
- fork bolt
- truss rod
- truss access
- mount holes
- T1 surfacing
- curved side
- T2 roughing
- heel edge
- keel slot
- head edge
- tall rough
- short rough
- head surface
- head profile
- T3 ball
- steep edge finishing
- heel finishing
- head finishing
- head steep edge
- T4 detail
- keel profile
- fork bolt
- T2 roughing
- flat side
- fingerboard
- neck side
- T1 surfacing
- T4 detail
- fork pocket
- truss rod
- mount holes
- T1 surfacing
- string side
- T2 roughing
- edge profile
- nut pocket
- T3 ball
- parallel surfacing
- T5 micro
- fret slots
- T2 roughing
- neck side
- head
- backside
- T2 roughing
- parallel roughing
- profile
- tuner holes
- T3 ball
- parallel finishing
- T2 roughing
- angled
- T2 roughing
- surfacing
- neck pocket
- T3 ball
- access port
- T2 roughing
- backside
- faces
- front
- T2 rouging
- roughing
- tuner seats
- tuner holes
- T3 ball
- parallel finish
- T4 detail
- bolt seats
- bolt holes
- profiles
- T2 rouging
- front
- aluminum plate
- keel
- T7 O-flute primary
- Surfacing
- Wide profile
- final profile
- T6 O-flute detail
- perpendicular drill sequence
- deck
- T6 O-flute detail
- drill sequence
- Surfacing
- Lower Surfacing
- Wide profile
- final profile
- T6 O-flute detail
- T6 O-flute detail
- tail
- T6 O-flute detail
- string end slot
- normal drill sequence
- Surfacing
- Wide profile
- final profile
- T6 O-flute detail
- fork
- T6 O-flute detail
- drill sequence
- Surfacing
- Wide profile
- final profile
- T6 O-flute detail
- T6 O-flute detail
- keel
- aluminum sheet
- cover plate
- T6 O-flute detail
- profile
- T6 O-flute detail
- cartridge
- T6 O-flute detail
- pockets
- profile
- T6 O-flute detail
- strap hanger
- T6 O-flute detail
- pockets
- profile
- T6 O-flute detail
- cover plate
- body
- G-code
Praxis Guitars
