1Step 1Slide the cover off of the Huawei E303 Modem and insert the Konekt SIM card.
2Step 2Plug the modem into your computer.
It should mount itself as a flash drive. The drivers for the modem will be on the drive. Go ahead and install them. -
3Step 3When the install is finished, it should automatically open up a web browser with the Huawei HiLink settings page. If this doesn't happen, open your web browser and go to http://192.168.1.1
4Step 4
Click Settings->Profile Management->New and add a profile for the Konekt APN (http://apn.konekt.io) as shown here:
5Step 5
Save all that and then go to the Connection Settings page. Enable all of the auto connect options as shown here:
6Step 6Finally click back to the Home page and click the connect button. You should be able to get on the network.
7Step 7Now unplug the modem from your computer and plug in your BeagleBone.
8Step 8The BeagleBone will also install itself as a flash drive at first. Open the Readme.htm file in your browser and follow the instructions to install the correct drivers for your computer.
9Step 9Follow the instructions on the Readme page to download and install the latest software image to the MicroSD card. You should use the latest image available from http://beagleboard.org/latest-images
10Step 10
If you don't already have an SSH client on your computer, then install the PuTTY SSH client from http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Reuben Balik
