very first test done, works, but needs finetuning
things to fix:
- the wheel encoder needs to be 0.5-1mm closer to the wheel, it's slipping sometimes (thus the space in the photo)- fine tune nut settings, each can seems to deliver a different amount of chalk
tomorrow starts gulasch programmier nacht gpn15. maybe i should go and finetune there.
