1Step 1I followed that tutorial to build the cable
2Step 2
Connect the Roomba RX wire to Arduino pin 0 (RX) and Roomba TX to Arduino pin 1 (TX).
3Step 3
To power the Arduino, you’ll need to convert the 20 volts from Roomba to 5 volts using a 7805 5V voltage regulator (see theses instructions).
