I will bring this project to the ccc camp from 13 - 17 August for working on the software.
A project log for Open Source Kinect stand-alone 3D Scanner
The idea behind this project is to provide an open-source stand-alone Kinect and Raspberry Pi2 based 3D Scanner.
Did you get around to work on the software or has the CCCamp camp-sniped you? ;-)
Yes, indeed! I ported an existing piece of code ( http://vr.tu-freiberg.de/scivi/ ) to the Raspberry Pi2. The software is runable on the Pi2 . But i had not the time to test it with the kinect until now. If it works with the kinect i will work on a nice UI for the small dispaly. I think this could be a fine starting point for the project.
