My aim is to build an RGB Desktop Lamp. It will be powered by an ESP8266 and a openHAB Server. It will also double as an Input Device for the openHab Server, allowing it to change the light directly on the device without the need for an Smartphone / Computer.
The actual switching will be done by CSD18504KCS. Also I´m working on implementing an Relay for the actual LED Power Supply for conserving power.
Xiider
Futience
