This is my first real project for Arduino, it is a tank that can be controlled by an Android device using a HC-05 bluetooth module. Please suggest any additions to this project and I will try to accomplish it.
Components
2×
9v batteries
1×
HC-06 Bluetooth Module
You can also use a HC-05 bluetooth module
3×
100k ohm resistors
You can also use one 100k ohm resistor and one 200k ohm resistor
I am currently designing a final permanent circuit using a perf board. I am waiting for most of the parts to arrive but as soon as the part arrives I solder them to the board. I'll post a final perfboard design when I am done.
May I suggest a "trainer" mode. Drive it through an obstacle course in "teach" mode, then let it show that it "learned" the lesson. It's the next step to being autonomous...
