This project uses an ESP8266 to control 8 relays to provide 24vac to operate a sprinkler control valves. It is a self contained web server, serving all the pages needed for configuration, status, and scheduling of up to 8 sprinkler zones for up to 30 schedules.
This project has been newly updated.. an OLED and a RTC added since the original project.
The code is held on GitHub and that is my preferred method for taking bug reports and feature requests (through the Issue system).
Kevin Uhlir
Liyanage Kalana Perera
RobertLukan
Hello, i have a problem the Wemos is not connecting to the existing SSID. It stops at Try: SSID and then reboots and try again.
Part of the logging:
FS File: /sched-schema.json.gz, size: 600B
config file: /config.json not found
sched file: /sched.json not found
set relays=00
going to STA mode Bundy
HTTP server started
"B⸮
nP⸮M%⸮⸮w⸮@⸮~⸮Q* ⸮G⸮
⸮5⸮⸮⸮⸮A*% )D⸮@⸮⸮@ ⸮Nz ⸮غNP9⸮)I⸮A⸮D⸮Ԛ⸮⸮
⸮Q⸮
