Hackaday.io Hackaday.io
Sign up Log in
Tube Boost Guitar Pedal
A guitar boost pedal running on a 12au7 vacuum tube.
redsquirrel7redsquirrel_7
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3k views
5 comments
144 followers
  • Description
  • Details
  • Files 0
  • Components 15
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
3k
5
144
15
Team (1)
  • redsquirrel7redsquirrel_7
Join this project's team
MUSIC Vacuum tube GUITAR vintage overdrive
Related lists
Guitar Projects
Guitars and Guitar Accessories
Guitar
Guitar mods, amps, pedasl etc.,
This project was created on 03/26/2014
Description
This tube boost/overdrive pedal is largely based on the Matsumin Tube Caster. This one features gain, tone, and volume control as well as a bypass switch. The 12au7 vacuum tube will only be running at 9 volts. This should produce a nice vintage tube sound with a little crunch to my electric guitar.
Components
  • 1 × 220k Ohm Resistor
  • 1 × 1M Ohm Resistor
  • 1 × 470k Ohm Resistor
  • 1 × 100k Ohm Resistor
  • 1 × Linear 50k Ohm Pot (gain)
View all 15 components
Project Logs
Collapse
  • Finished!
    redsquirrel_7 • 03/31/2014 at 14:32 • 0 comments
  • Finished Bottom of Tube Socket
    redsquirrel_7 • 03/26/2014 at 14:46 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Matthew Toledo wrote 04/03/2023 at 04:56 • point
I know this project is old, but does anyone have the schematics for how to assemble or is the photo the only schematic we need?
Eric Evenchick wrote 03/31/2014 at 17:53 • point
Nice looking pedal, but I'd be very worried about breaking that tube with my foot...
redsquirrel_7 wrote 03/31/2014 at 20:34 • point
It has a cover that goes over the tube to prevent that from happening. It looks cooler without it though. :)
FiveseveN wrote 03/26/2014 at 16:04 • point
This is a cool project if your're valve-curious but afraid of high voltage (as well you should be). Those interested can find a 170-page-long thread about this circuit and derivations on DIYSB: http://www.diystompboxes.com/smfforum/index.php?topic=63479.0
redsquirrel_7 wrote 03/26/2014 at 18:01 • point
I read a lot of this thread it is quite excellent and I also recommend it to anyone interested in learning about this circuit!
My attempt in making a ruben's tube that uses LEDs instead of live flames.
Project Owner Contributor
Digital Ruben's Tube
laurynas-ubysLaurynas Ubys
This is an AM radio made out of a Compactron tube, which contains two triodes and a pentode.
Compactron Tube AM Radio
tubetimetubetime
1 Watt Triode
Single Ended Tube Amplifier
liamLiam
2 Watt Pentode. 12AT7 and EL84
liamLiam
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Tube Boost Guitar Pedal", please tell us the reason.
Send message
Remove Member
