As the communication between ETS2 and the dashboard is working well, I designed a small tool which simulates the RNS Unit of the Volkswagen series. The tool is coded in Delphi / Turbo Pascal and plays up to six saved online radio stations. I'll integrate the ability to add your own radio stations later, too. Here some screenshots.
As always, thank you for your support!
