Today @Sepp and I equipped the PCB with the SMD components:
With this machine you're able to put the SMD components on the board.
The machine has a little camera on the positioning pin, so you're able to see what you're doing.
In the SMD oven the compents stick to the board with soldering cream, which becomes solder after 15 minutes of baking.
Thanks for the support! I'm courious when the project hits the 20.000 viewers mark.
Almost 20k :), nice lab you got there, can they fix burned UNO`s lol :)
I got help from my colleagues. So I equipped the PCB in our lab.
